Orbi WiFi 7 RBE973
Reply
Is the 60GHz 802.11ad working or how to turn it on
chenghongkw
I buy this wifi router last year. I have seen that the state of 60GHz LED is solid white.
So I thought that this AP works well.
However, I bought a 60GHz adapter, but I have no access to the 60GHz wifi.
So I check the configuration of the WIFI, I found this as shown in the following image.
there are two videos that I took to show that 60GHz wifi is working all the time.
you can see that the wireless AP is off. However, the light is valid light.
And when I change the configuration of the AP. the light of wifi will keep light.
So I think there is something wrong.
I have no idea how to turn on the 60GHz.
In the following, I show all of the attempts I have tried.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 4
Accepted Solutions
chenghongkw
Re: Is the 60GHz 802.11ad working or how to turn it on
Now it works. Maybe last time the new AP connected another AP.
This time I use an independent network cable.
Message 3 of 4
All Replies
Kamoj
Apprentice
If you install this, you can get some info about the 60 GHz as well.
https://www.snbforums.com/threads/kamoj-information-add-on-v4-for-netgear-r7800-x4s-and-r9000-x10-te...
Message 2 of 4
chenghongkw
Message 3 of 4
chenghongkw
Thanks.
Maybe my problem is from the wired network.
and this time I also didn't update the firewire of the AP and I choose router mode.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3309 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
