Orbi WiFi 7 RBE973
Reply
Netgear Genie App Not Displaying Traffic Meter Numbers Correctly with IOS 10
rrkrrk34
Tutor
Ever since I updated my Ipad Air 2 and Iphone 5 to IOS 10.0.1, the Genie app on those 2 devices won't display the Traffic Meter numbers--the numbers are blocked out. Both devices have been updated to IOS 10.0.2 and the numbers still don't display properly. I uninstalled and reinstalled the Genie app on both devices and the numbers are still blocked out. I tried an old Ipad 2 which isn't updated to IOS 10 and my Windows 10 desktop PC and the Genie Traffic Meter displays the numbers correctly. I called Netgear support, but they weren't aware of this issue and so far don't have a solution. Anyone encountered this issue on their Apple devices? Thanks! Another question--is there any way through the Genie app to have it tell me the amount of bandwidth/data usage per device rather than just in total for all devices? Thanks again!
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 7
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Netgear Genie App Not Displaying Traffic Meter Numbers Correctly with IOS 10
Hey All
I already have forwarded this to our engineering team.
There was another user who have submitted the same case.
Message 7 of 7
All Replies
Retired_Member
Not applicable
usage cannot be broken down to a device
Message 2 of 7
rrkrrk34
Tutor
Thanks for that piece of the answer. Here's a pic of what the Traffic Meter looks like on my Ipad Air 2 and Iphone 5 with IOS 10.
Message 3 of 7
Retired_Member
Not applicable
Have you checked the router via WEB Gui did you enter the ISP limit
Message 4 of 7
Pluto8
Apprentice
This error was introduced with IOS 10, and I am sure everybody who uses the Genie app on iPad/iPhone to check the traffic meter have the same problem. To correct this,  Netgear must update the Genie app for IOS 10 (I also have an Android tablet; on this the traffic meter is correct).
Message 5 of 7
rrkrrk34
Tutor
Thanks all for the replies. I haven't entered the data cap amount in on traffic meter yet. But it's probably right that Netgear needs to update their app to accomodate IOS 10.
Message 6 of 7
ElaineM
Hey All
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 5199 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
