- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 usb printer ink levels
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
i have the intention of purchasing the above router, but i have a question, i have an extremely reliable and cheap to run canon ip4850 inkjet printer that is usb only, its currently connected to an xpenology server which gives me info on ink levels etc, which is important to me.
Sadly in order to use the printer i have to switch the xpenology server on which isnt the greenest machine with a 2009 atom processor, so i would like to connect it to the R7000 router, does the router support two way comms such as printer ink levels?
secondly i have seen conflicting information about the inclusion of a bittorrent download manager, is there such a thing in the R7000?
Thanks for you help
scott
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stredwizard,
The router does not have an option to show ink level of your printer.
The router has the NETGEAR downloader option. Check the KB below.
http://kb.netgear.com/26250/How-to-configure-the-NETGEAR-Downloader-feature
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stredwizard,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7000 usb printer ink levels
Hi Stredwizard,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
