Orbi WiFi 7 RBE973
Reply
Nighthawk R8000 won't let me connect more than one device
Pudgie_japanese
Trying to set up new Nighthawk X6 AC3200 Tri-Band R8000 wifi router and it won't let me connect to more than one device at a time. I am using Apple devices and an XBox. Any ideas?
Message 1 of 7
Accepted Solutions
JamesGL
Master
Re: Nighthawk R8000 won't let me connect more than one device
Hi Pudgie_japanese,
You may try to reset the router to factory default.
Message 6 of 7
All Replies
Do you mean that you cannot connect more than one device to the R8000's wifi? (It is confusing to talk about connecting the R8000 to other devices.)
What happens when you try to connect a second device?
Message 2 of 7
Pudgie_japanese
Yes when I try to login to the wifi on my other devices it shows that there is no connection. I can turn wifi off on my phone and my Xbox can take over the wifi, but no more than one device connects at a time.
Message 3 of 7
JamesGL
Master
Hi Pudgie_japanese,
Access the UI of the router. (routerlogin.net or 192.168.1.1). Make sure it is not configured as AP.
Message 4 of 7
Pudgie_japanese
I've been trying to get to that but it seems it won't load on my cellphone. I don't have a laptop either. Thanks for the reply.
Message 5 of 7
JamesGL
Master
Hi Pudgie_japanese,
Message 6 of 7
JamesGL
Master
Hi Pudgie_japanese,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 5624 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
