- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X6 R8000 not getting gigabit speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X6 R8000 not getting gigabit speeds
Is there no netgear moderator on this forum that can discuss this? They broke our routers and are now telling us to wait for a firmware update that MIGHT fix our routers? What joke of a company is this? I can't believe I bought a Nighthawk router when I would've been better off with first gen mesh routers. Netgear sucks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jschraw thanks for biting the bullet and letting us know this is a Netgear problem. They really need to patch this soon. Once WiFi 6E is more affordable and mesh tech is better, I'm jumping off Netgear. I've had enough of their horrible customer service and satisfaction.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I logged into router, turned on and then off QoS (default was disabled) and set my speed manually (1000/1000) and it works. For a few hours, and then it resets back to about 200-280 Mbit/s, on all kinds of measuring sites. I'm wired with cat5e and have tested directly into the RJ45 outlet that receives the signal, plugged directly I get 950+ Mbit, but as soon as router is connected in between the outlet and PC, I am throttled.
I have found the issue and how to solve it, but the router keeps resetting the QoS and manual speed settings, every 2-3 hours, even though the interface shows the settings to still be the same.
So this router is faulty somehow and from reading multiple posts, it's not a device specific issue but rather a model specific issue.
I'm also surprised that a 250$ router has these issues that aren't even addressed and should I need support from Netgear, I'll have to pay even further $ for it... Least to say, I'm not likely to purchase other products from Netgear in the future as this is a truly disappointing experience and I can't seem to solve the issue no matter what I do.
Any tips or ideas from you guys in here would be greatly appreciated though, has anyone had the same issue with the proper settings being reverted despite showing them as being applied?
Thanks,
Best Regards
Daggz
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I gave up on Netgear long ago because the support was terrible, I was able to return it to Best Buy
and purchased an Asus ROG GT-AC5300. I have not had a problem since. Asus ROG has exellent support, I would definately recommend Asus.
Z
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried running FreshTomato for a while and that seemed to fix it. As soon as I went back to Netgear's firmware, the problem started again. Netgear really needs to fix this, this shouldn't be a problem for an expensive router like this
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far my "bypass" is using QoS manual settings which as others experienced will revert to slow speeds again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been reading this thread and have to agree with most. Netgear has totally dropped the ball on this. I spend $$$ on their router only to find out that they say "firmware issue, we'll get to it" and when 90 days of support runs out I'm up the creek w/out a paddle. I've been hammering on Verizon about slow speeds. Looks like I get GB speeds when connecting desktop direct to ONT (Cat 6). As soon as the Nighthawk is connected speed drops to 245Mbps. Done with Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What Firmware version is currently loaded? V1.0.4.76_10.1.82 (latest when I ran update check)
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Looks like a G-211M-C
I completely shut down my home network early this morning. All devices off. Waited 2-3 minutes. Reconnected router to ethernet, powered on, rebooted desktop. Ran a Verizon Speedtest and now at 950GB. We will see how long this lasts. Did this previously a few months back as part of a troubleshooting effort. Perhaps I need to do it every month? Seems crazy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
See how long it does. I'm currently waiting on a R8000 router to arrive.
Be sure your using good quality LAN cable between the ONT and Router. CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last FW update? Yes. Multiple times.
Be sure your using good quality LAN cable between the ONT and Router. CAT6 is recommended. I installed all Cat 6 cable. I tested and all connections are good. Verizon also tested with same results.
Connecting desktop direct to ONT has always resulted in 900+Mbps speeds U/L & D/L (essentially Gb speed).
Good luck with the R8000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Keep us posted on next time you see this happen and how many days/weeks it took.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So my slightly unused R8000 router arrived today.
Just got it connected and did some basic testing.
Router came loaded with v1.0.4.62. I didn't let it update FW. Wanted to test this out of the box first thought v76 was offered during the setup wizard.
Found 1 item that maybe a onboard/speedtest/speedtest service issue.
Speed test on the routers web page doesn't seem to seen anything near 900Mpbs on my 1Gb plan:
With a wired PC connected to the back of the router, ooklas speed test app does see over 900Mpbs on my 1Gb plan:
I'll monitor this to see if the external speed test app sees any drop in speeds over the weekend.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Speed check today:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Speed check again today:
Still rockin.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mines on v62 FW.
Factory reset the router and setup from scratch, I recommend NOT enabling QoS, Armor or Circle. As these see to slow down WAN to LAN perfomances.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If someone wants to start a lawsuit for settlement for anyone owning an R8000 and not getting their speeds nor support, I'd love to join
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue. I wake up in the morning run a bandwidth test from my browser I get 250mbps and the same when connecting to the Netgear Nighthawk X6 R8000 using it's internal bandwidth check. I found also that manually changing the in the section QoS. Selecting "I want to define my bandwidth " I enter my bandwidth specs and select apply. run the test again on my browser, now my speed goes to 403mbps where it should be. But here is the issue it does not hold the information as I have to do this sometimes twice a day to get the bandwidth I am supposed to get. If I hit appy to the manual numbers I eneter shoudn't it hold those parameters I selected? Is there a fix for this?
Firmware version
V1.0.4.76_10.1.82
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend doing a factory reset and setup from scratch. Do Not Enable the the following: Armor, Circle or QoS.
I'm on same v76 version and found that these seem to limit full bandwidth on 1Gb connections.
I've already reported the onboard speedtest is also inaccurate.
Also do not enable Smart Connect for WiFi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately I have factory reset the unit. I never use any of the things you mentioned as they do restrict bandwidth. so not sure what else I can do. I don't want to pay for support because they will only tell me things I have already tried. I guess I'll need to find another wifi router that actually accept parameters input. Thank you for your reply.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have Traffic Meter enabled?
If not, revert back to v62 version of FW and disable the routers FW auto update feature...My R8000 ran well with v62 loaded.
I feel there is problems with v76 FW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
