Orbi WiFi 7 RBE973
Reply
No Ethernet light
vansonly302
Follower
No Ethernet light
My CM700 cable modem has no Ethernet light when powered up. I have it connected to an Amplifi Gamers edition wireless mesh system. Had a power surge that fried my tv and router, assumed the modem was ok. Just got a replacement router today and plugged it in. But now the Ethernet light is not on.
Model: CM700|High Speed Cable Modem—DOCSIS 3.0
Message 1 of 4
Guru
Re: No Ethernet light
If you connect a pc/laptop to it does it work?
have you tried different lan cables?
Message 2 of 4
vansonly
Initiate
I have not tried plugging it directly into a laptop or other device yet.  I have tried multiple etherent cables including the brand new cable that came with the router.
I will try that later today.  I may just purchase a new modem.  I have been without internet long enough.
Message 3 of 4
Guru
It might be time for a new modem as storms are great at wrecking electronics.
But its always worth a shot with the direct connection
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 679 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
