Orbi WiFi 7 RBE973
Reply
Port Forwarding
jack3585
Port Forwarding
I have two web page servers on my lan. Their IP addresses are reserved. I have port 80 forwarded to one and port 8080 forwarded to the other. I can access both pages on the Lan by enterin the lan IP address and path to the pages. I can access the web page being forwaded thru port 80 but I cannot access the page on 8080. I cannot telnet to 8080. If i change the page on 8080 to 80 I can access it with no problem. How can I access both pages from the internet?
What am I missing here?
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 9
Accepted Solutions
antinode
Guru
Re: Port Forwarding
> Attached is what I have setup for port forwarding.
   Ok.  The obvious problem there is in rule 2: Internal Port 8080.
> 1. Yes. Both are listening on 80.
   If the web server at "192.168.0.17" is listening at port 80, then
forwarding to port 8080 there won't work.  What you should have would be
something like:
      External Port   Internal Port   Internal IP Address
            80              80            192.168.0.23
          8080              80            192.168.0.17
The internal ports are both 80. because that's the port where each web
server is listening.  The external ports can be (almost) anything you
wish.  80 is the default for HTTP (but you get to use it only once as an
_external_ port), and 8080 is a memorable alternate (which you'll need
to specify explicitly in a URL, like, say, "http://67.9.xx.xxx:8080").
> The router will not accept duplicate port numbers.
   That datum might have some value if you revealed what you were trying
to do, and what happened then, which led you to that conclusion.
>    When you do what, exactly?  "cannot" is not a useful problem
> description.  It does not say what you did.  It does not say what
> happened when you did it.  As usual, showing actual actions with their
> actual results (error messages, LED indicators, ...) can be more helpful
> than vague descriptions or interpretations.
   Still my advice.  Always my advice.  It's good advice.
Message 8 of 9
All Replies
schumaku
Guru
Re: Port Forwarding
The port 8080/TCP might be in use already, ie. in ReadySHARE or by UPnP PMP by a UPnP client on your LAN (a NAS, computer, ...) - check the related areas on the router.
Message 2 of 9
antinode
Guru
Re: Port Forwarding
> reserved.
   So, two different systems, with different LAN IP addresses?  And
those reserved LAN IP addresses are...?  Are both web servers listening
on (LAN) port 80?
> [...] I have port 80 forwarded to one and port 8080 forwarded to the
> other. [...]
   That's not a useful/complete description of port-forwarding rules.
Copy+paste the actual port-forwarding rules.
> [...] I can access both pages on the Lan by enterin the lan IP address
> and path to the pages. [...]
   Copy+paste the actual URLs which you are using.
> [...] I can access the web page being forwaded thru port 80 [...]
   Are you now talking about access from the outside world?  "access"
how, exactly?
> [...] but I cannot access the page on 8080.
   What are the actual URLs which you are using (from where)?  Hide your
public IP address if you want, but otherwise, copy+paste is your friend.
> [...] I cannot telnet to 8080. [...]
   "cannot"?  See above.
> [...] If i change the page on 8080 to 80 I can access it with no
> problem. [...]
   I don't know what any of that means.
> [...] How can I access both pages from the internet? [...]
   Appropriate port forwarding (and web server configuration).
   I can't tell without a clear description of what you're doing, and
what happens when you do it.
Message 3 of 9
jack3585
Re: Port Forwarding
2. Lan addresses are 192.168.0.17 to 8080 and 192.168.0.23 to 80. Both are reserved addresses. See attachment 1
3. When I just enter the Lan ip address, I can access the page. See attachment 2
4. Yes. I'm trying to access the page from the outside world. I am using NoIp to fix the external IP address.  Even if I enter my real external IP addtess, I cant open the page. See
      attachment 3.
Jack Parco
Message 4 of 9
antinode
Guru
Re: Port Forwarding
   Ok.  That sounds normal.
   Addresses are addresses; ports are ports.  What does "to 8080" mean
to you?  (I trust that you've noticed that only one attachment is
allowed per posting.)
> attachment 2
   "enter the Lan ip address" in a web browser's address window?  And
that works for both "http://192.168.0.17" and "http://192.168.0.23"?
> 4. Yes. I'm trying to access the page from the outside world. [...]
   Have you tried it from within the LAN using the external IP address?
   What are the first two octets ("a.b" out of "a.b.c.d") in your public
IP address?  Is that what the R6900 says is its WAN/Internet IP address
(ADVANCED > ADVANCED Home : Internet Port : Internet IP Address)?
   Still waiting for that.
Message 5 of 9
jack3585
Re: Port Forwarding
My external IP address begins with 67.9
I have tried connecting with 67.9.xx.xxx:8080 and it fails to connect.
I thought that 8080 is an alternate port fo HTTP 80. I'm new at this.
Message 6 of 9
schumaku
Guru
Re: Port Forwarding
For pure http or https (Web) you need just tcp (no udp).
The one with the port 8080 is named Arlo http - to my knowledge Arlo does not have any local Web based access. Is there a system listening on port 8080/TCP on that LAN IP (different from an Arlo?)
Message 7 of 9
antinode
Guru
Re: Port Forwarding
something like:
            80              80            192.168.0.23
Message 8 of 9
jack3585
Re: Port Forwarding
Thanks  for all the help. Using 8080 for the external port and 80 for the internal port solved the problem.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 7236 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
