Orbi WiFi 7 RBE973
Reply
Problem: My R7800 nighthawk router assign same IP for different mac devices
diralex
Hello,
I don't know why My R7800 router assign the same IP for different mac devices.
How can i fix that?
I have another access point with disabled DHCP and ip: 192.168.1.5.
The range ip addresses for my R7800 router, start from 192.168.1.21 to 192.168.1.254.
A screenshot attached.
Thanks.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 10
Accepted Solutions
diralex
Re: Problem: My R7800 nighthawk router assign same IP for different mac devices
hi @JamesGL
Thank you very much for your reply and concern,
This happened when I reserve an ip and reboot the router.
but, after turning off one of the duplicated devices and turn it on again,
the problem is solved and i don't know why.
Best regards,
Loui.
Message 8 of 10
All Replies
JamesGL
Master
Hi diralex,
1. What are those two devices that have the same IP address?
2. Can you check if the IP are set to static or obtain the devices side?
3. What is the firmware version of the router?
JamesGL
Community Team
Message 2 of 10
diralex
Hi JamesGL,
1.The first device is Roomba and the other is harmony ultimate.
2. The ip obtain the device side.
3. The latest firmware: V1.0.2.04.
Best regatds.
Message 3 of 10
JamesGL
Master
Hi diralex,
Try to reset the router to factory default and manually reconfigure. Check if the same issue happens.
JamesGL
Community Team
Message 4 of 10
diralex
hi @JamesGL
After factory reset, the same conflict with ip: 192.168.1.21.
Screen shot attached.
Loui.
Message 5 of 10
JamesGL
Master
Hi diralex,
If you check the IP address on the device(not through the device manager), will it show the same IP address? Can you try to configure the IP reservation if it will change.
JamesGL
Community Team
Message 6 of 10
JamesGL
Master
Hi diralex,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
JamesGL
Community Team
Message 7 of 10
diralex
hi @JamesGL
Best regards,
Loui.
Message 8 of 10
JamesGL
Master
Hi diralex,
I am glad to know that it is working now. Please mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
JamesGL
Community Team
Message 9 of 10
diralex
Thank you very much.
I marked the solution.
loui
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 4830 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
