Orbi WiFi 7 RBE973
Reply
R7000 Traffic Meter is not working on V1.0.11.106_10.2.100
pathwalker
Hi all,
I have tried setting up the router to keep track of data usage even though my plan is unlimited. The connection is PPPoE
If I go to Advanced > Setup > Internet Port > Show Statistics, I am able to see the Tx and Rx Pkts are increasing.
Appreciate if any expert or tech support can point out to me what setting did I miss out. Thank you.
Cheers,
Pathwalker
Message 1 of 6
Guru
Re: R7000 Traffic Meter is not working on V1.0.11.106_10.2.100
The photo you put in the post doesn't show but the one you attached does.
Is the one in the post different?
(fyi, photos imbeded need to be approved by a moderator and can take several days)
Message 2 of 6
pathwalker
This second picture is about the port statistics access from Advanced Tab> Internet Port > Show Statisticsr7000-2.JPG
Message 3 of 6
Guru
try putting a time in to start instead of 00:00
try 00:01 or something
Message 4 of 6
pathwalker
Hi plemans,
  Thank you for your suggestion. I have tried putting in non 00:00 at starting time. Unfortunately, I am still getting all zeros as screenshot attached.
Message 5 of 6
Guru
the R7000 has a newer version of the firmware out. Have you tried it?
What modem/gateway is it connected to?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 491 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
