Orbi WiFi 7 RBE973
Reply
R7000 has half the wifi speed as ethernet connection
AthleticsFan
I have "gigabit" internet via Xfinity.  I am running my own SB2800 cable modem and using a R7000 for the router (V1.0.9.88_10.2.88).  I am getting the same speeds (900+) directly out of the ethernet ports on the router as I am if I connect directly out of the cable modem via ethernet.  Wifi, however, tops out at around 400.  This is within 8 feet of the R7000, utilizing the 5g channel, with a very strong connection.  I am on a Macbook Pro with:
AirPort Extreme  (0x14E4, 0x152) on a Firmware Version: Broadcom BCM43xx 1.0 (7.21.171.134.1a2)
I don't have QoS enabled and parental controls are not enabled.  I have resset and restarted the router many times.  Is this the fastet that I can expect with the R7000?  If I want to get closer to the 900 mark, do I need a different wifi router?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
Accepted Solutions
IrvSp
Master
Re: R7000 has half the wifi speed as ethernet connection
Router is fine, but I suggest you read and understand this web pages:
https://www.forbes.com/sites/gordonkelly/2014/12/30/802-11ac-vs-802-11n-wifi-whats-the-difference/#4...
https://www.lifewire.com/how-fast-is-a-wifi-network-816543
Not knowing the wireless device 802.11 speed nor the number of antenna's, I'd say you are doing good. The R7000 and most other routers have 2 antenna's per SSID. Some do have MU-MIMO capability (Google it if you don't understand) but that too requires a router with that feature and a wireless device that has it as well.
It all comes down to matched h/w capability, the router and device. Just like many phones have AC capability, all that means is they can connect to a 5Ghz SSID usually.
Oh, the fairly new 802.11 AD devices, well, there are not many, and not many routers that put that speed out. However some devices have poor record of reaching the speed and f/w is not mature.
Message 3 of 4
All Replies
yddtime
Luminary
Why are you expecting more than 400 on WiFi? Do you know what your WiFi adapter on the device is actually capable of in a real world scenario? Specs are usually under ideal conditions which never actually happen.
Message 2 of 4
IrvSp
Master
Message 3 of 4
AthleticsFan
Thank you very much for the great information!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2123 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
