- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router R7000 keeps going offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router R7000 keeps going offline
Mmmm....
Strange, i have the same problem, started a few weeks ago.
but my router R7000 is 6 years old, so i didn't try much.
i'ts updatet an rebooted a few times,
and becouse it's 6 years old, i bougt new gear.
But iI am sure it's my router, not my modem.
Did you do a factory reset??
That's the next thing I'm going to try.
Bu don't know when i have time for it.
Today I have installed the new router, so my problem is solved 😉
Try the factory reset if you didn't do it already.
mvg.
Mlap.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
But holding the little reset button for a second of 20 in, wil do a factor reset.
Be sure you know the default logging 😉
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue that started a couple of weeks ago. My router is less than 6 months old. I called for support and they wanted me to spend $90 for a support package. I just spend $200 on the router, so I am not spending $90 for support. Any community help out there would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
BTW, I did a factory reset already
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried everything for this issue. I even took my first R7000 backl and pleaded with Best Buy to let me exchange it so luckily they did. My 2nd one is doing the same thing and I've called Support, since it is new, several times. Many of the solutions are silly solutions, like unplug the ethernet and blow the dust out, you must be having power outages, it is just normal for it to go offline everyonce in a while. I had a couple of good techs who helped me change the mac address which helped for about a week and now it is back going offline about twice a day. I'm just going to take this one back and get a different brand. I had lots of confidence in NetGear until now. My daughter has this exact model NightHawk and the same exact ISP and hasn't had any issues for almost 3 years now! If NetGear support can't even help me, I don't want to continue with this!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I too use to think Netgear was the way to go, but I too have lost faith. I am running into this problem as well and on version 1.0.9.88_10.2.88. Have to reboot the the router at least twice a day.
