- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router configure after Cox Gigablast upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router configure after Cox Gigablast upgrade
Be sure the isp modem router is bridged.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
What are the wired speeds seen at the R9000 router?
What wireless devices do you have connected to the R9000 router?
You'll only see around 300-500Mbps on 5Ghz AC with a wireless device. Depending upon device support and design.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wifi on the R9000?
How did you setup and configure the R9000 for AP mode? Use a dynamic or static IP address configuration on the R9000? Static is recommended.
Be sure to connect the R9000 to the host router using the yellow WAN port of the router to connect to the host routers LAN port.
Be sure your using a good quality LAN cable. CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Look at the host routers connected clients page to see if the R9000 got a IP address, it should be listed here, you can connect to the R9000's web page using the new IP address it got from the host router, if the R9000 is connected right.
Couple of items to review to see if they can help:
https://www.youtube.com/watch?v=mXpGKBle-0s
Not same looking interface however same principle area and section:
https://www.youtube.com/watch?v=0Y1b_hp9rQ0
If you have a neighbor, friend or family member that can help you, please ask.
