Orbi WiFi 7 RBE973
Reply
Setting up a static IP with Nighthawk R7960P
mocajoe
Hello!
I'm using a Nighthawk R7960P cable router and wish to set up a static IP for one of my laptops. I've searched all over the documentation for this router, looked at web searches, and looked over ever Administrative privilege and option in the router to no avail.
I'm using firmware version V1.4.3.88_1.3.50. I'm all patched up and current.
If anyone can send me directions or to the correct area of the Administrative privies, I'd appreciate any help!
Thanks a ton!
-Jason (aka: mocajoe)
Message 1 of 4
Accepted Solutions
microchip8
Master
Re: Setting up a static IP with Nighthawk R7960P
Static IP is set on the device itself. What you're most likely looking for is a DHCP Reserved IP. You can find that in Advanced -> Setup -> LAN Setup
Message 2 of 4
All Replies
microchip8
Master
Message 2 of 4
mocajoe
YOU ROCK! Thanks for such quick and responsive help! Have a great Monday!
Message 3 of 4
Guru
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1039 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
