Orbi WiFi 7 RBE973
Reply
Specific device not connecting to router while other are connected, works plugged into modem
basketballmap21
My new work laptop is not connecting to wifi. It will say 'no internet, secured' or look connected, but not load anything.
All of my other devices are still operating normal.
I tried resetting the router to factory settings but that change anything. Model: R6700v3, all firmware up to date
My work laptop will connect fine to wifi on campus, or work with my cell phone hotspot. Just not my wifi at home.
I plugged into the router directly with ethernet, it still did not work. Plugging directly into the modem did work.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 4
Guru
Re: Specific device not connecting to router while other are connected, works plugged into modem
Are you using a work vpn?
What modem/gateway is the router connected to?
Message 2 of 4
basketballmap21
Not using VPN as I can't even get on the internet. It is connected to an Arris SB6190.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 665 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
