Orbi WiFi 7 RBE973
Reply
Unable to Un-Register R7100LG Router from ReadyCloud
DMac11
Stuck in a bit of a loop.
Due to my USB device's (1TB Samsung portable HD) continually disappearing and then re-appearing in ReadyCLOUD I un-registered my router from within my ReadyCLOUD account with the aim of re-registering it to see if that would fix the issue.  Having done so I then went to the router's Genie page to also unregister the router from my ReadyCLOUD account, but everytime I click on the Unregister button I get the following "Unable to remove your registration. Please try again.".  Now stuck in a loop, anyone any ideas?
Model: R7100LG|Nighthawk 4G LTE Modem Router
Message 1 of 6
Accepted Solutions
DMac11
Re: Unable to Un-Register R7100LG Router from ReadyCloud
Issue solved by Netgear Support.  Unit being RMA'd.
Message 3 of 6
All Replies
DMac11
Bump!
A picture paints a thousand words:
I have un-registered my router on the ReadyCLOUD account and now need to log into my router to register it.
But when I go to the router to register it, as you can see below it is already registered to my ReadyCLOUD account, try as I might, I'm unable to un-register it:
Can anyone help?
Regards
Dave
Message 2 of 6
DMac11
Message 3 of 6
Issovits
Hi, i have the same problem, but i got a used one and now it's too old to get support.
Can anyone help me with a workaround ?
Message 4 of 6
Guru
Something to contact NG support about:
https://my.netgear.com/support/contact.aspx
Message 5 of 6
schumaku
Guru
Usually a factory reset (-> Nighthawk AC1900 WiFi LTE Modem Router p.176) does remove the ReadyCloud registration all (all?) Netgar routers.
Don't be confused: The product registration (independant of ReadyCloud) can't be removed - just skip that part.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1757 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
