- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
VPN connection from OpenVPN Android on R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am no more able to connect to the VPN of my R7000 with the last OpenVPN app on Android.
I think is a problem of compatibility but I don't know how to solve it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN connection from OpenVPN Android on R7000
Has anything changed recently?
Try a power OFF of the ISP Modem and router for 1 minute then back ON.
Try a full on factory reset and setup from scratch...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
On your Android device, the OpenVPN application keeps a log file. It may contain information on why the connection is not being made successfully.
How old is the profile configuration file on your Android device? If your router has had a recent firmware update you may have to update the configuration file on your Android device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I solved using the OpenVPN connect app on Android and it works perfectly.
The other one (OpenVPN for Android) can't connect.
