Orbi WiFi 7 RBE973
Reply
WIFI in multiple rooms
PeterMa
Follower
I'm trying to find a solution to have internet in one of the rooms in my place, it's a 2 level split apartment. I also already have a Netgear powerline + WIFI extender which are working fine.
Level 2: the living room where the router and powerline are connected. There's bedroom 2 in this level where the WIFI is very weak
Level 1: Bedroom 1 with the WIFI extender
What can I do to get the WIFI to reach properly in bedroom 2, can I just buy another WIFI extender and that will connect to the powerline already set up? So essentially I have 1 x powerline connected to the router and 2 x WIFI extenders in separate rooms in different levels that are connected to this powerline?
Message 1 of 2
Re: WIFI in multiple rooms
It  might help if you told us what Netgear devices you are using.
For example, what is this Powerline device? Is it one with wifi built in?
You can use a wifi extender in access point (AP) mode and use Powerline ethernet as the connection back to the router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 483 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
