Orbi WiFi 7 RBE973
Reply
X6S AMA - Does it work smoothly with Apple Airport Extreme?
Lasse63
Follower
X6S AmA
Message 1 of 2
Accepted Solutions
arunkmony
NETGEAR Employee Retired
Re: X6S AMA - Does it work smoothly with Apple Airport Extreme?
Hi Lasse63,
Thanks for your question. Nighthawk X6S is universally compatible with any router. FastLane3 on X6S connects to any router including Airport Extreme. If you are asking about Smart Roaming then there are various factors involved like device capability, where you position the router and extender, how many devices etc. 802.11k is supported on Nighthawk X6S to make the handoff smoother. We also have other algorithms that will make the roaming experience better.
Message 2 of 2
All Replies
arunkmony
Hi Lasse63,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1117 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
