Orbi WiFi 7 RBE973
Reply
adding AP's to Nighthawk R8500 half duplex
1ndnman2
I have a Nighthawk R8500 that comes up short of covering the area I need. Are there AP's that I can connect via Ethernet and the AP's running on full duplex?
Also, will I have to add a POE switch for the 2 or 3 AP's to be hardwired to? What model of AP's should I buy for full duplex?
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: adding AP's to Nighthawk R8500 half duplex
I would suggest our mesh extenders you can run then as AP or in extender mode.
https://www.netgear.com/landings/mesh-wifi-extenders/
DarrenM
Message 2 of 5
1ndnman2
Thanks Darrin for the reply. So I can use my Nighthawk R8500 and connect 2 Mesh extenders.
Is the R8500 POE ports? Or do I have to run the cat6 from the R8500 to each mesh extender, then power it locally?
Last question, are these extenders full duplex or half duplex?
Thanks again Darrin
Message 3 of 5
DarrenM
No Poe you can use the extender via wireless if you do not want to run Cat 6.
DarrenM
Message 4 of 5
1ndnman2
If I use the extenders via wireless is it running half duplex?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 526 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
