× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
NIGHTHAWK AX6 AX4300 - Update error
Shiva3758
Tutor
I continue to get an Update Error when I try to update the router. Any suggestions on how to remedy?
MODEL: AX6 AX4300
MAC IOS     15.16
HARDWARE VERSION.      RAX45
FIRMWARE  V1.0.11.112
Message 1 of 9
Accepted Solutions
Shiva3758
Tutor
Re: NIGHTHAWK AX6 AX4300 - Update error
Thanks for your help. Despite the prompts to update the firmware on the IoS mobile app, the firmware appears to be the latest available version. Appreciate everyone's input.
Message 8 of 9
All Replies
Guru
what update error do you get?
Are you using the app or going through the browser?
Have you tried manually updating?
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
Message 2 of 9
Shiva3758
Tutor
I am using App. I get a screen with image of product with header UPDATE ERROR. Bottom of screen choices are SKIP and TRY AGAIN.
Message 3 of 9
Try the manual update that @plemans recommended.
Ir is safer and more reliable than the app.
Message 4 of 9
Shiva3758
Tutor
I tried the manual update. Trying to download the update.
Got this message below.
The IoS APP says there is an update.
This process says there is not an update.
This is such a confusing process with Netgear.  Thoughts?
Firmware Version Check
No new firmware version available.
Message 5 of 9
Guru
What actual version are you on?
You can compare your current version versus the one on the support site.
Nighthawk RAX45 | WiFi 6 Router | NETGEAR Support
Message 6 of 9
That seems to be the latest version:
RAX45 Firmware Version 1.0.11.112 | Answer | NETGEAR Support
Not sure what the problem is!
Message 7 of 9
Shiva3758
Tutor
Message 8 of 9
Makes a change. The usual problem is that apps say "firmware up to date" when there is a fresher version available.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1288 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
