Orbi WiFi 7 RBE973
Reply
Nighthawk X6S Tri-band or Nighthawk AX12
cdoan
Tutor
Hello guys!
My current service is Cox Gigablast Internet w/ a Netgear CM1000.
I ran a Nighthawk X6S Tri-Band Wireless Router a couple days ago and now I have the Nighthawk Ax12.
Having connection issues with the AX12 (dropping and resetting to factory everytime I push the reset/restart button; wierd) Really fustrated the AX12.
The Nighthawk X6S Tri-Band ran flawless and fast w/out issues. I want to go back, but the AX12 has a lot of the bells and whistles advertised.
Should I keep the AX12 and hope the issues gets fixed w/ a new firmware or go back to the X6S Tri-band.
We currently havce 18 devices connected to the router. 80% of it is connected to the SMART CONNECT (5ghz channel).
Appreciate any input! Thanks! Would love any advice on tweaking the setup to maximize my speed.
Message 1 of 2
Newfiedrool
Virtuoso
Re: Nighthawk X6S Tri-band or Nighthawk AX12
Is this the RAX120 or RAX200.
this will apply to both but I would also recommend you check the support pages too for hot fixes which need to be installed manually.
once you are sure it's up to date then perform a reset using the rear pin hole method. Setup as new with out using a saved config and see how it goes.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 827 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
