- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAXE500 Link Aggregation Not Working
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased a Netgear RAXE500 recently and I'm on the latest firmware (V1.0.5.62_2.0.35).
I am unable to setup link aggregation on. I have tried both static and LACP mode using a Netgear and a TP-Link switch. But, none of them seem to be working. After turning on link aggregation, the Netgear router fails to provide a DHCP address to the connected switch and then the switch defaults back to its self-assigned IP address. I think there might some issue with loopback in the network when link aggregation is turned on.
Is anyone else using this router and been able to successfuly setup link aggregation?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAXE500 Link Aggregation Not Working
On your switch, did you enable LACP on the 2 ports that you have connected to the router? Both the router and the switch must have LACP enabledd otherwise you will run intl an unusable connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, obviously. I setup LACP on both the router and the switch and then connected the cables on both ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello mshasib,
Have you had a moment to reach out to our support team regarding this? Newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/contact.aspx
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Christian_R ,
A case has been open since 05/18/21. Unfortunately, there is still no resolution on this.
I am surprised that support has not been able to provide me a solution in spite of both my devices being Netgear.
I would appreciate if you can escalate the case.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello mshasib,
May you provide me with your case number and I'll reach out to our support teams.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Christian_R ,
It's Case # 44581105
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latest firmware is V1.0.6.64, did you upgrade already?
- Mark as New
- Bookmark
- Subscribe
- Permalink
With some managed switches, it can get tricky getting LACP working right, especially when they offer a ton of different methods and hashing types, where it could end up requiring some trial and error.
TP-Link tends to offer a bunch of options on their managed switches for hash algorithm, number of ports used, passive or active LACP, etc.
