Orbi WiFi 7 RBE973
Reply
Orbi Satellite not showing in web interface but showing in IOS app
ScubaSteve63
The Orbi Satellite is not showing in the we interface but does show in the IOS app.
I have seen posts for the opposite of this but not vice-versa.
Thanks,
Steve
Message 1 of 13
Accepted Solutions
Guru
Re: Orbi Satellite not showing in web interface but showing in IOS app
What version of the app are you using?
Maybe @CrimpOn can comment as well.
Might try a full on Factory reset and setup from scratch.
Might try this version of FW as well:
https://community.netgear.com/t5/Orbi/Missing-Connected-Devices/m-p/2143646#M126249
Message 8 of 13
All Replies
Guru
Is it working?
Can you hardwire into it and it works?
Message 2 of 13
ScubaSteve63
It is hardwired and it's working well...just confused on why the web interface does not show it
Message 3 of 13
Guru
What Orbi model is this?
What web browser are you using?
Message 4 of 13
ScubaSteve63
RBR50 with chrome as browser
Message 5 of 13
Guru
What model is the RBS? 50 as well?
Happens with MS Edge or Firefox?
What firmware version is loaded on the RBR and RBS?
Message 6 of 13
ScubaSteve63
Same result in Edge
Firmware is 2.7.3.22
Thanks
Message 7 of 13
Guru
Message 8 of 13
ScubaSteve63
App Version is 2.15.1.2
Everything is working...just odd that the web interface is not showing satellite or attached devices and the IOS app does
Message 9 of 13
CrimpOn
Guru
I agree that the most frequent posts are concerning issues with the way the 'app' displays components and the typical advice is "check the web page."  This one may remain a mystery.
There would be no harm and almost zero effort in rebooting the router and satellite. (not a "Factory Reset". that can be a lot of effort.)
Message 10 of 13
Guru
Might try a factory reset on the RBR and setup from scratch.
Message 11 of 13
ScubaSteve63
I am going to try the .33 firmware update tonight and will let you know if that works.
Thanks,
Steve
Message 12 of 13
ScubaSteve63
Updating the Router and Satellite to V2.7.3.23 fixed the problem !
Thanks for all the help !
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 3268 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
