- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New to Netgear : what devices should I look at?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
New to Netgear, I am exploring the idea to buy Netgear Orbi Pro APs for a small office (3 APs + switch), 15 to 20 people.
ISP provides a FTTH connection with ~ 600Mb/s bandwidth.
The switch will also receive direction ethernet connection of 4 VoIP phones.
Usage is : VoIP, Google Meet, browsing, file exchange, Team Viewer mainly...
I would like the APs to broadcast 2 SSIDs : MyCompany-Staff & MyCompany-Guests
People connected to MyCompany-Guests will have their traffic reach the internet through our ISP directly, while people connected to MyCompany-Staff will be tunnelled to a VPN (SSTP) and reach the Internet through the the provider of the VPN service.
MyCompany-Staff will have no limit in usage.
MyCompany-Guests may be capped to a max of 50Mb/s usage in total.
Is there a way to separate the traffic of these two SSIDs in VLANs and setup and maintain a SSTP VPN connection on Netgear Orbi Pro devices?
Can it be done in the APs or should a specific device (which one) be added at the edge of the network before the ISP router?
Thanks for your help,
ltr
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New to Netgear : what devices should I look at?
What is the size of your home business building? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your reply @FURRYe38 !
The building is on one level only, approx 1200 sq ft, rather elongated rectangle shape : approx 80 x 15 ft.
The router would be in the middle and the satellites on each side of the rectangle, at a distance of let say 30 ft from the RBR.
There is a brick wall in the path of the signal from the RBR to the two RBSs.
---------------------------------------------------------------- | | | RBS RBR RBS | | | ----------------------------------------------------------------
After reading the description of the product, I am not completely sure if the RBS are connected to the RBR by a wire or by a dedicated wifi channel. Or perhaps both can be done?
And about the VPN, can the RBR initiate a SSTP VPN session and tunnel the traffic into it? (not for Guest SSID)
Thanks in advance.
ltr
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
For that size of home just a Orbi router alone would be good enough or maybe with just one RBS. Having too many RBS in a smaller size home may cause problems or be problematic at least.
https://kb.netgear.com/31489/How-do-I-use-VPN-on-my-Orbi-system-with-my-iOS-device?article=31489
