Orbi WiFi 7 RBE973
Orbi Pro SRK60 - Ethernet backhaul vs WiFi backhaul for mesh WiFi in large multi-story house.
Marco-F
I have read in some blogs that for the Orbi Pro SRK60 system it is better to establish a WiFi backhaul using the dedicated radio signal between units, rather than the Ethernet backhaul.
As I'm designing the system for a large house and 5 satellites, I have the opportunity to have wired connections in a daisy-chain design.
I was assuming the Ethernet backhaul is far more reliable and stable than the WiFi one.
If so, why someone would suggest to rely on the WiFi backhaul instead?
Thanks.
Model: SRK60B06|Orbi Pro Tri-Band Business WiFi System
Message 1 of 3
Accepted Solutions
evan2
NETGEAR Expert
Re: Orbi Pro SRK60 - Ethernet backhaul vs WiFi backhaul for mesh WiFi in large multi-story house.
@Marco-F
Yes, Ehternet backhaul is more reliable and stable than the WiFi backhaul,
If you have the opportunity to have wired connections in daisy-chan, you had better use Wired connections.
Message 2 of 3
All Replies
evan2
NETGEAR Expert
@Marco-F
Message 2 of 3
Marco-F
@evan2 wrote:
@Marco-F
Great! Thanks for confirming!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3341 views
  • 0 kudos
  • 2 in conversation
Announcements
