Orbi WiFi 7 RBE973
Reply
SXR30 and Verizon FIOS
cpolizzi
I am trying to replace the CR100B Verizon Router with an SXR30 Router and 1 satellite.  I have reset the router to factory settings and it ended with a solid white light.  I connected to the router using same cabling from working system.  Reboot fiber optic modem and then power up SXR30.  I hard wire with my computer, go through the Netgear setup but end up with a Magenta light and no internet connection.  I haven't used this router in some time but it did work before.
SXR30 firmware is 4.3.4.200
Any insights would be appreciated.
Message 1 of 10
Accepted Solutions
cpolizzi
Re: SXR30 and Verizon FIOS
I spent 2 hours in a chat with Verizon and they were no help whatsoever.  They would not answer a question as basic as, "Do you support 34d party routers in place of your own equipment?"
However, I did finally find the attached document.  It appears that the ODN holds onto the IP address lease for their modem blocking attempts to replace their router.  By issuing a command to release the IP address on the Verizon router and immediately unplugging it, I could then install the SXR30 with no issues.
Note that the document is from Verizon.  All they kept saying was they didn't recommend 3rd party devices as they had a bunch of value added features that they could not elaborate on.
The Verizon solution was to replace the router with an older version (a CR1000A instead of CR1000B) and add 2 network extenders of their own.  The newer router my son already had would have to be hardwired to the extenders while the older one could work wirelessly.
Message 9 of 10
All Replies
Guru
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS8...
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Message 2 of 10
cpolizzi
I don't think I explained correctly.  I am disconnecting the Verizon CR100B and putting the CXR30 in its place.  The modem is a Nokia P/N 3FE52343APBB
Thanks.
Message 3 of 10
Guru
Something to ask the ISP about. Ask them about any special WAN side configurations or if the ISP gateway is required or can be replaced.
Message 4 of 10
CrimpOn
Guru
When I search for Verizon CR100B, the only hits appear to be for a CR1000B
Message 5 of 10
cpolizzi
Yes.  Sorry.  I dropped a 0.  It is a CR1000B
Message 6 of 10
CrimpOn
Guru
Very strange.  I cannot find any mention in the CR1000B User Manual of putting the device into 'bridge' or 'passthrough' mode.  This article mentions outright replacement using exactly the method you describe:
https://www.reddit.com/r/Fios/comments/1d9wv5o/need_help_getting_rid_of_cr1000_fios_router_and/
Message 7 of 10
Guru
Message 8 of 10
cpolizzi
Message 9 of 10
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 923 views
  • 0 kudos
  • 3 in conversation
Announcements
