- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware update RBR750
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I cannot update the firmware of RBR750 Orbi Router. The current version is V4.6.5.29_0.0.33 which does not have smart parental control. Moreover, automatic update does not work for the firmware. I downloaded the firmware from the website for manual upgrade but the file extension is .chk while as per user manual, it should be .img.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware update RBR750
Something odd going on here.
I see no sign of that ever being firmware for this device.
Orbi RBR750 | WiFi System | NETGEAR Support
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try manually updating FW. RBS first then RBR lastly:
@nmeskin wrote:
Hi,
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I downloaded the new firmware but it is .chk extension and the manual update does not consider it as the new firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
.chk is the file format that the RBS and RBR take. Be sure your using a web browser and selecting the .chk file thru the RBS or RBR manual FW update page. Be sure your using the RBS.chk file for the RBS and the RBR.chk file for the RBR.
Try using a different browser. MS Edge, Firefox or Opera all work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I have the file RBR750-V4.6.9.11_2.3.5-signed.chk. I used both Safari and Chrome and I am getting the following error:
Firmware upgrade failed. Please check your file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you seeing same thing on the RBS? Be sure to update the RBS first then the RBR lastly. RBS use the RBS.chk file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would you confirm that this is the right FW version on your RBS and RBR?
I don't see this in NGs prior FW version history.
Is this Orbi system a retail system you bought someplace online or did you happen to get it from a ISP company by chance?
@nmeskin wrote:
Hi,
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
As I said in my first response, what baffles me is that your current firmware does not seem to exist. Certainly not for the RBR750.
I went and checked as soon as I saw your post. (Evidence always beats boilerplate answers.)
Your picture shows this:
This is what I see:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
@nmeskin wrote:
Hi,
Regards
