neomatrixwood's avatar
Feb 14, 2024
I am unable to connect my replacement RBS850 to my network
I am unable to connect my replacement RBS850 to my network.  I have tried all manner of troubleshooting including hardwiring.  In the last case it is added to the network but I cannot get log into the satellite - password is rejected.
A few things I notice since it is a replacement it is likely to have different FW.  I cannot update FW as I have no laptop (MAC OS) to connect directly.  I suspect it is a FW incompatibility issue as when I try a wireless set up it won't sync and flips to Magenta even if it is in the same room as the router.
I would appreciate any insights.
  • FURRYe38's avatar
    And thats after a factory reset on the RBS and it not connected to anything accpet for the one wired PC? Be sure to clear out all browser caches? Would need to turn OFF the RBR.
    Last resort is to try a 30-30-30 reset on the RBS.
  • FURRYe38's avatar
    You'll need to get a ethernet connected Pc or laptop connected behind the RBS to get the FW updated to same version as what's on the RBR.
    Try this to see if this works:
    Manual RBS FW update after RBR was updated:
    You need to update the RBS before updating the RBR. Keep this in mind for future updates.
    What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite📡. Already have the most current FW version files downloaded on to this PC.
    Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite📡. The RBS will be 192.168.10.250 for Orbi AX. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and <password>. Use the satellites 📡 web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites 📡 to the RBR.
    • neomatrixwood's avatar
      neomatrixwood
      Tutor
      Thanks for your help.  I have tried to connect to the satellite using an ethernet adapter (TP USB-C to Ethernet) on a MacBook Pro. It appears that what is detected is the adapter and not the satellite.  I have not be able to access the satellite via the IP address even though I see a Blue status light when it is hardwired for about 30 seconds.  I have used 192.168.1.250 which is what I think you mean.  I have reset and rebuilt the network, cycled the network etc.  I am sure it is the F/W unfortunately cannot crack how to update the satellite.
      • FURRYe38's avatar
        Try accessing the RBS at 192.168.10.250
  • schumaku's avatar
    schumaku
    Your new RBS850 default Local network (LAN) configuration is this:
    LAN IP 192.168.1.250
    Subnet mask 255.255.255.0
    In absence of a DHCP server on the wired network (currently consisting of the Mac and the RBS850 with a direct connection) a Mac does tend to use ZeroConf IP addresses.
    Temporary configure the Ethernet adapter to a fixed IP address, for example 192.168.1.234 subnet mask 255.255.255.0 - in case the system insists for defining a default gateway and/or a DNS server address make it 192.168.1.1. https://support.apple.com/guide/mac-help/use-dhcp-or-a-manual-ip-address-on-mac-mchlp2718/mac
    Now you are able to reach the new RBS850 on it's default LAN IP, like http://192.168.1.250/ or https://192.168.1.250/
    The default user name is admin. The default password is either password, the password printed on the label, or the password configured at the first login.
    This should allow to upload the same firmware version you already have on your Orbi Router and the other (predefined) satellites. The process is described in https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf chapter "Manually update satellite firmware " starting from p. 94 ff.
    Once the new satellite does hold the same firmware like your existing Orbi router (and other satellites) https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf chapter "Sync your Orbi satellite with your Orbi router" starting from p.14.
    • FURRYe38's avatar
      RBS for AX and AXE series have a self service web page at 192.168.10.250. Given enough time after a RBS is reset and NOT connected to any thing, this self service web page can be access at the afore mentioned IP address if a ethernet connected PC is connected behind the RBS. Might need to set a statis IP address on the PC of 192.168.10.49/255.255.255.0 to help with this. Usually 5 minutes is needed before the self service RBS web page should be accessible.
      • schumaku's avatar
        schumaku
        Perfect FURRYe38 ... learning something new every day here, thank you! Found your prevous post here on the similar topic - looks much easier than what old network crowds would try.
