Orbi WiFi 7 RBE973
Reply
Intermittent DNS Errors and WiFi Issues
Tobamory
Tutor
Re: Intermittent DNS Errors and WiFi Issues
Thanks Furry
Message 501 of 579
houcatdad
Star
I have the Rbk752. I was given the beta firmware and just loaded it 30 minutes ago.
I can confirm the DNS problems are gone. Browsing is snappy AF and there don't seem to be issues.
Ehhhh.... while writing this my phone just said wifi disconnected... and it came back. Might just be an anomaly.
It's definitely browsing good!!!!!
Fn finally!
Message 502 of 579
Guru
Did you power OFF the RBR and RBS after applying the beta update?
Fn finally!
Message 503 of 579
ngflguy
Can someone please share a link to the beta firmware with me? I have the RBK752 as well and I have been fighting this issue since February.  I have tried all the work arounds but the DNS issue still haunts me. Encuraging that the firmware to fix this issue will be widely released soon, but would love to run the beta firmware in the meantime.
Message 504 of 579
Guru
Sent.
Message 505 of 579
ngflguy
Thanks @FURRYe38 . Applied the RBR750 first and then the RBS750 second and worked like a charm.  I have been running it for almost 2 hours now and no DNS failures!
Message 506 of 579
Guru
Good to hear. Always apply the RBS first, then RBR lastly in the future.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Enjoy. Smiley Wink
Message 507 of 579
SeaRefractor
Apprentice
Thank you for the beta firmware.   I'd received it and have applied it.
While annecdotal, it already feels crisper/snapier in response that prior.    I know it'll take time to be fully certain the DNS issue has been resolved, but I think I may have had more of a DNS performance impact prior than I knew.
Same computers are resolving and serving up content quicker than before the beta.    Thumbs up so far!
Message 508 of 579
Guru
Good to hear. hHould be good now.
Enjoy. Smiley Wink
Message 509 of 579
Guru
@msinex
Ok for ALL you 8 series Orbi users, please make contact with @Christian_R
Ask for access to Firmware v3.2.18.223. Beta is ready and being made available for those who want to try this version.
"Unknown/Phantom Satellite is showing up in the Orbi App
Netgear logs of Satellite are not collected in GUI debug logs
DNS issues"
Once you get the files, update the RBS first then RBR lastly. I would power OFF all units for 30 seconds then back ON. Same with your ISP MODEM/ONT.
If any issues are still seen, you'll need to do a factory reset and clean setup from scratch.
I would encourage for those having DNS issue to give this a try. Seems to be fixed for 7 series users. Smiley Wink
Message 510 of 579
BooBooJeffries
^Thanks. Just sent a PM. I never received a reply from any previous PMs to them.
Message 511 of 579
Guru
Let me know if you don't get a reply today...
Message 512 of 579
Thanks! Just sent a request myself. Did a cutover this morning and had to refresh alot. Looking forward to this fix!
Message 513 of 579
rr20552
Apprentice
Was given access to the series 8 beta which I have now applied.
DNS issue appears to have been resolved and internet appears to be much faster.
So far so good.
Now all we need is parental filtering!
Message 514 of 579
Guru
Please make a post about this in the beta thread as well.
Thank you for letting us know.
So far so good.
Message 515 of 579
energie
Luminary
I might give the beta a try later on as well, at least some positive news - after 12 months. Currently I have the Orbi's in AP mode and things are now just 'working' perfectly. I noticed that the DNS/NAT handling on the Orbi's was different (worse) compared to the Asus. So I am curious to find out if with the fix for the DNS issue this also got changed.
Message 516 of 579
Guru
Let us know your results when you test it.
Loaded mine last nite. I turned off 6to4 and using ISP DNS. Everything default for DNS. Nothing special or any work arounds being used.
Message 517 of 579
Validus
Luminary
Testing the Firmware v3.2.18.223 Beta on the Orbi Netgear RBK853 appears to have resolved the DNS Issues. Running nicely so far. Will update if any issues detected, so far none using IPv4.
Message 518 of 579
Guru
Message 519 of 579
unyin
Can I get the Beta firmware for RBR750 and RBS750? I DM'd Christian this morning and haven't received a response. Thanks!
Message 520 of 579
Guru
Its the weekend here so please be patient.
Message 521 of 579
sepsole
Glad to read this.
I will ask the beta firmware to @Christian_R . My RBK852 system has been working very badly the last month... I hope the beta firmware will solve the issues.
Message 522 of 579
bullm00n
Virtuoso
I installed the beta on Friday.  I did the RBS850 first, then the RBR850.  The I powered everything down for a minute and restarted.
The only issue I had was I could not access the RBS wia WEB browser.  I rebooted it and it worked briefly, then no access. It did work and I could get to it through the phone app and connected devices worked.  I decided to remove the wired backhaul connection and restart the RBS.  I could then access it with the WEB browser and all was fine.  I left it like this on Saturday and today, I switched it back to wired and it has been fine all day.  So I think something with the upgrade made it necessary to re-establish the backhaul with wireless first, then switch to wired.  Otherwise all is fine so far.
Message 523 of 579
Amcbroom81
Tutor
I am also wanting to try the beta, iPhones and iPads have issues connecting or acting like there is no internet. Try to load apps or web pages on phone and nothing, so I get frustrated and turn off my wifi and use my phones internet. Hope this Beta can help
Message 524 of 579
Guru
Please make contact with @Christian_R to get access to the beta.
Message 525 of 579
Top Contributors
Announcements
Orbi 770 Series
