- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Nest Thermostat Batteries LOW on a new ORBI AX setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nest Thermostat Batteries LOW on a new ORBI AX setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll try that as well though it would consider it a work around and not a solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
voltage drop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just curious what is the distance of your NEST controller(s) from the RBR and RBS respectively?
@Booya wrote:
I’ll take a work around until the real problem is fixed since this is a relatively least work involved. Let me know how it works out for you. The Nest thermometer battery voltage has held steady and doesn't show any
voltage drop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far, my Guest network approach continues to work without issues. It’s an unfortunate but relatively painless solution until/unless it can be eventually be addressed correctly by Netgear / Google.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did the guest SSID thing and it successfully worked to get my Nest connected to the Internet. However, when I'm not able to connect it to the Nest App and during the process the the battery drains and the screen goes black and laggy. I ended up plugging into USB to get the battery back up. Anyone doing the guest SSID thing having trouble connecting to the Nest App?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I put my 8 series back online last Sataurday using the following process:
Been watching my 3rd Gen NEST thats closest to the RBR. 4-5 feet. Have not seen the NEST go off line since. Just checked the voltage on the NEST and it's at 3.89volts. NEST is not power wire connected as of yet. Just wireless. Last time I saw the NEST was connected to the basement RBS which is wirelessly connected to the RBR on 2nd level. I'll keep monitoring.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Finally was able to get it working using the Guest SSID trick. Thanks so much for the tip!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats the distance between the RBR, RBS and your NEST controllers. I found that distance can be a factor.
Current working version of FW that seems to work with my 1 3rd gen NEST is v3.16. No low battery was seen with my 8 series Orbi.
@Crawfordiii wrote:
I tried the same thing and it worked! Battery level keeps charging as mine is connected to the C wire. We will see if it holds once I do that for my other Nest Learning Thermostat. Ridiculous that neither company of the two most highly rated products in their prospective categories can't or won't solve this!
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is somewhat unrelated, but I had to remove one of my Nest Power Adapters today. Now that the cold weather is here I noticed that one of my A/C compressors would run for 1-2 seconds when the heat turned on (it's not supposed to do that). I'm am 100% sure the Nest Power Adapter was wired up properly, but it was causing this behavior.
Interestingly, I have 2 HVAC systems in my house. Both the same brand, but different models (one is a "regular" furnace and the other is a high-efficiency). The high efficiency unit operates normally with the Nest Power Adapter installed (the A/C compressor does not briefly turn on with the heat).
- « Previous
- Next »
