- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
New - RBR750 / RBS750 Firmware Version 4.6.14.3 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RBR750 / RBS750 Firmware Version 4.6.14.3 Released
Glad it was an ISP issue and they fixed it. Finally.
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
After long hesitation I've just upgraded from 4.6.9.11 and the speed on wifi has dropped for all devices (usually getting 400-500Mbps, now I'm getting 150-180Mbps). I've changed nothing in configuration, so I wonder if anyone has experienced this.
I saw a recommendation to set the IP range to 100-200 for DHCP after upgrade, but not sure if that will change anything at all. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
IF this doesn't change the issue, then a factory reset and setup from scratch will be needed. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RBR 750 has V4.6.9.11_2.3.5
Is that OK?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your system is working you don't have to update FW.
Is that OK?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems to be working fine. Thanks for the response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you.
I will do that. Great advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- Next »
