Nayef1's avatar
Nayef1
Orbi Wi-Fi xfinity issue
On speed test the speed is coming in full throttle but Wi-Fi browsing and apps like twitter and YouTube are not working properly. If I connect to Orbi through LAN, every thing works great. I think something went wrong with my Wi-Fi specifically.
Should I do a hard a reset to resolve?
  • FURRYe38's avatar
    What Orbi model are you referring too?
    Power cycle the system first OFF for 1 minute then back ON?
    Try a reset as well.
    • Nayef1's avatar
      Nayef1
      RBR750.
      I’ll try the power cycle for 1 minute. I tried 10 seconds before.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
  • CrimpOn's avatar
    CrimpOn
    Some additional detail would be helpful:
    • Which Speed Test is showing the expected speed?
      • A Speed Test report from the Orbi router web interface or the Orbi 'app'?
      • A Speed Test run on a device wired to the Orbi?  (Such as Ookla Speed Test)
      • A Speed Test run on a device connected to Orbi over WiFi?
      • If the Speed Test was a report from the Orbi, then it would be very helpful to use a web browser to connect to Ookla Speed Test and measure speed from both a wired and WiFi device. https://www.speedtest.net
    • In what way are apps like Twitter and YouTube not working when connected over WiFi?
    • What sort of devices is this happening with? (more than one?)
    • Is it safe to assume that everything was 'normal' until just recently?
    • Nayef1's avatar
      Nayef1
      Speedtest over wifi on iPhone and MacBook. Just started happening recently.
      Either it opens tweets, videos and webpages very slowky or won’t load them at all.
      Wired speeds and Wi-Fi speedtests are consistent.
  • "Don't Do Speed Tests through a Web Browser."
    Get the actual SpeedTest(.)net App and run it on all the Clients your are needing tests from. Through a browser is very inaccurate.
    P.S.
    Bridge Mode on the XB7 works with DOCSIS sources only, not Fiber. But the XB8 says it's 100% Bridgeable. Xfinity has a page on how to put it into Bridge Mode. With a lot of sales pitches.
