Orbi WiFi 7 RBE973
Reply
Outdoor Wi-Fi with RBR850
BSTNWHLR
I have an Orbi environment. One RBR850 and four RBS850 satellites. I need to extend my Wi-Fi network outside further than these indoor units cover to support some security cameras. What options will work and is there a “best” option?
In a previous generation of Orbi I used an RBRS50Y outdoors. But it is not compatible with the RBR850.
Help?
Message 1 of 5
Guru
Re: Outdoor Wi-Fi with RBR850
RBS50Y is compatible if you load up the Extender mode FW on the RBS50Y.
What is the distance between the router and 📡 satellite(s)?
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Outdoor-Satellite/m-p/2130002/highli...
Message 2 of 5
BSTNWHLR
Thank you for this very useful suggestion!  I had not thought of this.  It looks like a good option.  Only concern I have is what happens to the strength of the wi-fi signal given it is inside the box?
Message 3 of 5
Guru
If the box is not metal, signal should now be degraded badly. Should be good.
Message 4 of 5
NGSvensk
Apprentice
I am using a  RBS750 in a weatherproof box with my Orbi 852 and it works great.  RBS750  was used instead of a RBS850 due to the price
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1208 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
