× You're Invited! Orbi RBK763 Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Reply
RBR850 - WiFi Backhaul constantly disconnecting
bmacmillan
Follower
I recently moved my office in my house and am relying on the backhaul connection between the RBR850 and one of it's sattelites to provide ethernet connectivity to my desktop.
I'm having an issue where every once and a while (ranging from 30 seconds to 5min), I'm still able to ping my gateway (across the backhaul) but can't ping google (8.8.8.8 for example).
From another PC wired directly to my internet I don't drop a single packet, only when the ping is sourced across the backhaul.
I'm at a complete loss for what to do, any help would be appriciated.
Message 1 of 4
Guru
Re: RBR850 - WiFi Backhaul constantly disconnecting
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
Cortez254
Switched to AP Mode and running through an Untangle firewall. It gives me much more control and logs everything to a local syslog instance. I'm also out of forced and poorly tested firmware updates.
Message 3 of 4
Guru
Any progess on this?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 387 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
