Orbi WiFi 7 RBE973
Reply
RBS850 Out of Sync error
VerneArase
Apprentice
Lately, whenever I reboot the router my living room satellite comes up "Out of Sync" - I need to go over and power it down and back up to get a "Good" status.
This node has been problematic in the past - but it seems that Netgear aggresively resists replacing any equipment.
Is this normal? The Pro Support guy seemed to indicate it is.
Don't think it happened before 4.3.6.16 - but then again it didn't happen when I first put on this firmware so I don't think it's a software issue.
Does this happen to anyone else?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Guru
Re: RBS850 Out of Sync error
Usually a good power OFF of the RBR and RBS takes care of that from what Ive experienced. Or a remove the RBS from the RBRs web page, factory reset the RBS and manually re-sync it. Give it like 5 minutes after it reconnects.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 3
Dd852
Luminary
Furrye38's suggestions are precisely what I've done in the past with an out of sync satellite. I had bought the one satellite 850 version, then bought a second satellite and that one has always been a bit problematic. But a factory reset followed by a manual resync seems to have kept it nicely stable.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 617 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
