- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware check error
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pg 89 of the user manual gives information on how to do FW updates thru the RBRs web page:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Just try to remember that the RBS needs to be updated first, then update the RBR lastly.
Enjoy.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware check error
Is this via the Orbi app or RBRs web page? Plese use a PC connected to the RBR and web browser to update the FW on the RBS first, then the RBR lastly.
If your system is running fine, you may want to not update as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This was through the ORBI app.
Yes the system is currently running fine but since the email I received stated the latest fw is v2.3.5.30 which will enhance the product security, I thought I should update.
Any thoughts? Or just leave as is since everything is running ok?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes users are seeing odd issues with the Orbi app. We recommend using the RBR web page for doing any FW updates.
However if your system is running fine, you'll be ok to leave it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
