- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is My CBR40 dying after only two years??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Over the last week, my CBR40 (+ one satellite) seems to be struggling. First, I'm no longer able to access via the orbi app (previous posts' suggested solutions haven't worked), only via browser. Second, the wired router isn't working - I have two computers connected to the base via ethernet, and the satellite is also hard-wired - so unless all three of those ethernet cables died simultaneously, the problem is with the router in the base station). Wireless is working OK, is there an upper limit to how many wireless devices can connect? Not sure what to do, but it doesn't seem like I should have these kinds of problems with a 2.5yo device that has largely worked flawlessly until this month?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is My CBR40 dying after only two years??
Hi billForbes,
Welcome to the NETGEAR Community!!!
I understand that you are having an issue connecting your satellites to your CBR40. Please reboot your system then check for connectivity between satellites. If there is still no connection then reset your system using the 30-30-30 reset method.
For more information about factory reset please navigate to the link below:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Please navigate to the link below for supported connected devices:
https://kb.netgear.com/31097/How-many-devices-can-my-Orbi-system-support
Best,
Kevin
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a factory reset about 90 days ago and that worked. This time I was able to simply power down, unplug all ethernet cables, and then power up and plug them back in one by one. Everything is back to normal, but this feels indicative of a hardware fault in the physical router itself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is loaded on the CBR and RBS?
What is the distance between the CBR and RBS?
What CAT# lan cable are you using? CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
CBR40 is Orbi Firmware Version V2.5.0.28_1.0.8, CM Firmware Version V1.01.06
RBS is V2.5.1.16
its about 40 feet, however they're hard-wired together
yes, all CAT6
- Mark as New
- Bookmark
- Subscribe
- Permalink
So only the Orbi app is not connecting?
There was a Orbi app issue seen about 30 days ago.
You may want to submit a bug report:
- Mark as New
- Bookmark
- Subscribe
- Permalink
there are two problems:
1. the physical router periodically stops working, solution seems to be to reboot, and then reseat/insert all the ethernet cables at the CBR40
2. the orbi app is not connecting - none of the referred suggestions are working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi billForbes,
Thank you for your update.
Please check your PM.
Best,
Kevin
Community Team
