- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mixed Lan with orbi AC3000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the following product Orbi AC3000 Tri-band WiFi Router (RBR50) and I would like to create a mixed local area network using a network switch to connect devices such as pc, smart tv, printer and dvr, such as switch, with at least 6 ports; and which network cable do you recommend since I should upgrade to fiber?
What do I need to wire such a network in a three-story house by passing the cables through the existing light conduits?
Orbi AC3000 Tri-band WiFi System (RBK53) #lan
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Those will work find until your ready to upgrade.
I recommend getting the non (E) versions of the switches.
I found a bit cheaper pricing by getting used or refurb'd equipment.
Good Luck.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mixed Lan with orbi AC3000
As long as the RBS gets connected to the back of the RBR, with a non managed switch in between, your good there.
If you have in wall lan cabling, these just need to be connected to this switch as well.
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series 8 and 24 port switches work for Orbi systems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wanted to ask what type of cable and switch I need, the tools and any since I would have to wire the house.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please don't take this the wrong way, but.........
The forum has posts every week which point to in-wall cabling being responsible for serious issues. I recommend starting with an internet search for "how to install cat6 cable in house", and read at least 10 articles.
What can be obvious and nearly trivial to a professional installer can overwhelm a beginner. Cat6 is indeed the recommended cable these days, but it is a real frustration to install. That plastic spine used to separate the four twisted pairs makes Cat6 cable hard to bend. (Kinking the cable can harm performance terribly.) Terminating the wall jacks is not trivial. Be prepared to cut off and discard the first half-dozen jacks. Consumers also do not have access to professional testing tools. The inexpensive cable tester from Home Depot simply verifies that each of the 8 wires on one and are connected at the other end. It does not verify that performance meets expected standards.
I serious recommend calling out an professional telecom installer to talk over your options. Perhaps there is part of the work you can do yourself.
Good Luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to find a compromise between the available space in the installation pipes, cable quality, fire protection in the electrical installation (legal requirements).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the option of using the trunking of the telephone sockets, in this case which cable do you recommend?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I want to create a rack, what do I need?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
In addition to the switch, I would also install a network disk in the rack to share data, as well as allowing me to extend the wifi signal to places where it doesn't reach.
Or is the switch enough?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
In what sense?
I'm new to networking and wanted to figure out what's the best choice for extending my network and wifi signal by sharing data and a printer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I would like to buy the netgear gs 308v3 switch to connect to the router and I would need another 5 port switch to connect to the gs308v3.
Which do you recommend?
Browsing on Amazon I noticed that there are two versions gs308 and ge308e, what is the difference?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enter GS308 on this page: https://www.netgear.com/support/ and it will display nine different models of the GS308.
The base model is listed as End of Life. It is totally unmanaged (but great as a switch)
https://www.downloads.netgear.com/files/GDC/GS308/UnmanagedSwitches300_DS_24Apr14.pdf
The GS308e is a managed switch, supporting VLANs and other features.
https://www.netgear.com/images/datasheet/switches/GS305E_GS308E_DS.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it a good switch to create a LAN at home?
Which 5-port switch do you recommend to connect to the aforementioned switch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unless physical space is an absolute deal breaker, the 5 port model of this switch costs $1 more than the 8 port model (Amazon).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have to connect the 8-port switch to the router, as 6 LAN cables will arrive while I have to connect the 5-port switch to one of the cables where I have to connect 3 devices (dvr, smart TV and a box)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which switches (one with 8 ports and one with 5) do you recommend for cabling the network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Who will cable my network told me that he will pass a UTP cable inside the electrical outlets, is that ok or should I ask him to pass a shielded cable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
NGs GS series GS-105/108 work well with Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was looking at the gs305/308.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
