- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netflix / Amazon Prime not connecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
We however just realised that our Sony smart tv’s will not connect to Netflix or Amazon prime. The tv will also not connect to either of their websites either. All other internet sites and apps are working...eg YouTube on both tv’s
Also we have no problems connecting to Amazon / Netflix on other apple devices (tablet / MacBook )
Finally, we did struggle accessing PlayStation Onlinr Services which was eventually solved by changing the MTU figure In the custom set-up (Reddit gave us the solution)
Any thoughts would be appreciated
Carl
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
Is Armor or Circle or IPv6 enabled on the RBR? Try disabling these 3 and see if this changes anything.
Has a factory reset and setup from scratch been performed since last update?
If your on a DSL ISP service, try setting the MTU value to 1472 or 1492 for DSL ISP services.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netflix / Amazon Prime not connecting
How are the TV sets configured with regard to the network?
i.e. Are they set up to use DHCP to get their network information?
(IP address, subnet mask, gateway, DNS)
Have the TV sets been powered off and back on after the network reconfiguration?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@carlos45 wrote:
We have recently reconfigured our router / modem set up with orbi system acting as a router and the nighthawk set to modem only. This has worked perfectly for the last few weeks
Try going into your TV settings, do a soft boot or soft reset. There should be instruction in your manual. Then remove and reconnect the WIFI network.
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
- Mark as New
- Bookmark
- Subscribe
- Permalink
If by FW you mean firmware then everything is up to date
Circle has not been enabled on the Orbi.
We have factory reset the tv and performed the usual soft and hard reboots.
Yes I believe we are on a DSL ISP service. Re the MTU ..is this something I can change on the Orbi / Modem or is it configured on the tv.
I needed to change the MTU to access PlayStation online services however this was done thru the PlayStation as opposed router / modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All other internet access for the tv is fine. You tube etc
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully all other internet functionality is fine.
Thank you for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Enjoy.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
