Orbi WiFi 7 RBE973
Reply
Orbi Satellites
Orbi_Amatuer
Orbi Satellites
I have an Orbi system with 2 Satellites.
I have a question about the "Attached Devices" list as seen when logged into the Router as administrator.
Each of my my satellites have unique names.
So I can see which device is connected to what satellite in the "connected orbi" column.
Example: iPhone A connected to Orbi 1.
However, I have a couple devices that sometimes show connected to "Orbi Satellite" but not specifying which satellite it is actually connected to.
Does this imply it might be trying to connect to more than 1 satellite?
Kind of like it's trying to make a decision for which satellite to connect to based on signal strength?
Hoping to learn more about this.
Thanks.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 10
Guru
Re: Orbi Satellites
To see which RBS a device is connected too, log into the RBSs web page and review the connected clients on each RBS there.
Message 2 of 10
Orbi_Amatuer
Re: Orbi Satellites
Ah Ha.
Are you telling me there is a way to login directly to a sattellite to view connected devices in addition to logging into the router to see the connected devies?
If my undersanding is correc, tHow do I get to the login of each individual satellite?
Message 3 of 10
Guru
Re: Orbi Satellites
Yes, Look for the IP address assigned to the RBS on the RBRs web page. Use this address and same RBR log in info on the RBS web page.
Message 4 of 10
Orbi_Amatuer
Re: Orbi Satellites
Thanks FURRY!
That helped.
I think i'm intermittently loosing connection to the satellite so the router gets dumb.
Message 5 of 10
Guru
Re: Orbi Satellites
Has a factory reset and setup from scratch been performed since last FW update? Something to try if you haven't.
Message 6 of 10
Orbi_Amatuer
Re: Orbi Satellites
Thanks again FURRYe
Router in Basement
Distance
Router to Sat 1 in kitchen.
Est 20 ft. through basement ceiling. Drop ceiling, metal HVAC ducts, ceramic tile, drywall and kitchen cabinets.
Router to Sat 2
Est 25 ft. through basement ceiling, 2 walls, some concrete could be weakening the signal.
Sat 1 to Sat 2
Stationed at about the same height. Est 30 ft apart. through 4 walls.
2.4Ghz is set to channel 1
5Ghz is set to channel 48.
Suspect connections are on 2.4Ghz network.
Lots of neighbor WiFi signals but I frequently check channel usage in the neighborhood with NetSpot.
Beamforming ON
MIMO OFF
WMM ON
IPV6 OFF
Enable 20/40 MHz Coexistence (This is checked as enabled) Does un checking it imply 40MHz only?
Preamble is set to Automatic.
I just changed it to short.
What is Coexistance and Preamble?
Message 7 of 10
Guru
Re: Orbi Satellites
Basements are not recommended places for wifi routers. Concrete and steel will inhibit wifi travel.
IF you have lots of neighbors near by, try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Yes, unchecking the box sets 40Mhz only.
Message 8 of 10
Orbi_Amatuer
Re: Orbi Satellites
changing to 40MHz only seems to help.
Reducing power caused more dropping out problems.
I wish I could individually set the poer level for each RB unit.
I know, basement is no good but it is what it is. Thats where all cable connections come in. I'm not yet up for running cables.
Thanks again.
You've been very helpful.
Message 9 of 10
Guru
Re: Orbi Satellites
Ok you can change the power levels back. See if just chaning to 40Mhz only will help.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1499 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
