- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 plus 3x RBS50v2- Satellites - loosing connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
I could not get consistent connection with 2 sattleites, and so after i installed 3rd RBS50 v2 my entire netwprks started acting up. I have about 26 devices on the network 2500SQ ft house - Any ides ??? Firmware updated on all 4 devices to the latest . Rebootes the crap out of all devices. Reset all the DHCP settings... Intermittent connection loss all over , most notecible on TVs and Laptops.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 plus 3x RBS50v2- Satellites - loosing connections
@AJ1234, stating "latest" firmware does not tell us what version is installed. If you are running v2.5.0.x firmware, it was retracted by Netgear after many bugs and stability issues were found. NG disabled autoupdate in recent releases due to the issues that it has caused. I suggest manually upgrading your RBR50 to v2.5.1.8 available from https://www.netgear.com/suppzio fort/product/RBR50.aspx#download if you are not already running it on the RBR50 router and all of the RBS50 satellites.
1. Backup your settings of the RBR50 router (in case you need to restore or revert)
2. Download the zip file for both the RBR50 router and any satellites you have
3. Unzip the files
4. Manually upgrade the firmware on the satellites first using their image file
5. Finally, upgrade the firmware on the RBR50 router using the RBR-v2.5.1.8.img file
- Mark as New
- Bookmark
- Subscribe
- Permalink
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
Has a factory reset and setup from scratch been performed since last FW update? Please do this after updating FW to v2.5.1.8. Ensure you update the RBS first then the RBR lastly.
2500 sq ft home maybe too small for the RBR and 3 satellites. Try using the RBR and 1 RBS.
@AJ1234 wrote:I could not get consistent connection with 2 sattleites, and so after i installed 3rd RBS50 v2 my entire netwprks started acting up. I have about 26 devices on the network 2500SQ ft house - Any ides ??? Firmware updated on all 4 devices to the latest . Rebootes the crap out of all devices. Reset all the DHCP settings... Intermittent connection loss all over , most notecible on TVs and Laptops.
