Jjersey63's avatar
Jjersey63
Apprentice
Apr 28, 2022
Lost web access to Orbi router - RBR750
I generally login to my router daily - I noticed last evening the Orbi was rebooting - I didn't reboot it but now I can no longer web into it or use the app to access the interface.
I can still ping the interface 10.0.0.1 and also all web traffic is fine - I just can't manage this anymore.  I've done all but factory reset this - I did back up the config but I really don't want to factory reset this.
Any ideas?
  • There's clearly an issue with the latest firmware across multiple generations of Orbi routers that's causing the router interface to not be accessible via web browser or the Orbi app. I own both RBR850 and CBR750 (both with satellites) which are setup on completely separate networks in different physical locations (work and home) and after this latest firmware update, neither of the routers are accessible through the web browser or Orbi app... yet the routers still continue to function...their interfaces just can't be reached any longer.
    • Jjersey63's avatar
      Jjersey63
      Apprentice
      Ok - figured as much - I am running v4.6.7.13 - updated a few weeks back and all seemed OK.
  • plemans's avatar
    Does it work through the app?
    Have you tried a different web browser?
    If its on the 10.0.0.1, you're probably in a double nat.
    Maybe that's causing an access issue.
    Have you tried disconnecting it from the modem/gateway its connected to, reboot the orbi, and then try connecting to it (without it connected to the modem/gateway)?
      Jjersey63
      Apprentice
      I can’t access it via the app or the web browser - I’ve tried rebooting it without it connected to the RG (uverse using pass through mode) no joy.  The satellites are accessible just fine but the router web page won’t come up and the app keeps telling me the router is offline.
      Jjersey63
      Apprentice
      I am leaving for a trip on Sunday and I don’t want to factory reset this yet.  I have a config saved off but I am afraid if I reset this and I still can’t access the interface, I am hosed.  I have over 60 connected devices and a factory reset is a last resort.
  • I am having the same issue. Any one figure this out yet?
    Thanks!
    • FURRYe38's avatar
      Factory reset and setup from scratch using a wired PC and web browser at HTTP 192.168.1.1. Don't use Orbi app.
      Thanks!
      • fanandfoe's avatar
        fanandfoe
        Guide
        Fellow owner of a Orbi 750 fully configured with 2 satellites where, inexplicably, I can't access the web interface and the app says that my orbi is "offline". I have tried different computers and different browsers. All the same result.
        Power cycling the router does not help the situation.
        GRR Netgear! $600 in router gear should not be doing this!
      Jjersey63
      Apprentice
      So here is the latest for me - I need internet for remote work - no downtime or very little.  Since it’s not clear to me a factory reset will work, I dropped another $600 for a “plan b”.
      I spoke to another geek and he had the same issue as me.  Internet was fine, just no web/app access to router.  He factory reset his and he never could access the router, essentially it bricked.
      So I spent another fortune and will hope I don’t need to open the box and just return it to Costco but I need an alternate plan if this goes so south.  If I brick my router, is Netgear going to compensate me and others?  I’ve been doing IT work for over 40 years, this ain’t my first rodeo and I can understand why Netgear would push security updates (because most users never check once it’s setup) but that isn’t me.  I plan all my patch updates - backup files, blackout plans etc. and to have a forced update without warning is flat out wrong.  Checksum are validated, ensuring download site vs. what is downloaded is good before I start.  Not sure what was done during this update, but geez give me the chance to plan this before NG jams this down my router.
      So I have the firmware that is on the web site staged, will try to factory reset tomorrow morning and see what gives.
      • FURRYe38's avatar
        Factory reset with the RBR and a wired PC should bring access to the RBRs web page. Just walk thru the setup wizard in a web browser. DO NOT USE ORBI app to set it up.
