Orbi WiFi 7 RBE973
Reply
Blocked web sites on mobile but not on mac
Allenmccloud
Since installing my Orbi I cant access some web sites on my mobile iphoneX. On my Mac its ok but on phone blocked. I have checked both phone and Orbi for child safety and everything is off so can't understand. If I go to another wifi spot I can access but not at home. Any one help? Allen
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Guru
Re: Blocked web sites on mobile but not on mac
Have you setup any IP address reservations for the Mac and iPhone?
Have you enabled any Circle or Armor freatures on the RBR when you first set it up?
Message 2 of 5
Allenmccloud
Hi Furrye38
The firm wear is v2.3.5.30
The modem is Virginhub3
No reserved IP addresses
No Circle set up
I have checked all safety blocks available on both iphone and router and all are set to off so no sites should be blocked. My friends get the same issue when they log into my wifi. Its only here it happens out and about on other wifi its ok so presume its something here thats causing it in Orbi?
Allen
Message 3 of 5
Allenmccloud
Looks like I have done it. I went on to orbi log in and activated Standard Parental Controls. It seems its the wrong way around when its on its clear when its off it stops sites.
Message 4 of 5
Guru
What mode is your VirginHub3 running in? Router mode or modem only mode?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
"It seems its the wrong way around when its on its clear when its off it stops sites." What do you mean by this?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 681 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
