- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LAN ports stopped working
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LAN ports stopped working
Hello dpass83
Have you done a factory reset by holding the reset button for 10 seconds? Also have you updated to the latest firmware?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dpass83
You may want to contact support if there is a hardware issue with your unit.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
My LAN ports stopped working also. If I plug anything in to them the whole roouter shuts down.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No switch attached. It was working fine for about 2 months and now if i attach anything to the LAN post it turns Magenta and stops working. Router works great with nothing else attached.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello MollyDg
Have you factory reset the unit and updated to the latest Firmware? If so you may want to contact support if this is still happening.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DarrenM,
I tried resetting and do have the latest Firmware. Like I said works great wirelessly. But when I plug in something to the LAN port, stops working, turns magenta. Tried calling support and they just told me the same thing to update and reset. Any other ideas???
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would call back to support and tell them none of those solutions worked could be a hardware issue.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did anyone ever find a fix for this?
Have done resets etc.. and have spent hours on the phone with support. Still no answer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Plugging in a simple Netgear switch (Model FS105) makes my Orbi quit working. Unplugging the switch from the Orbi makes it work again. Not sure why this is, but it's annoying. If I'm limited to three ethernet ports in one room and four in the other, it's going to be a very bad situation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I too experienced the ethernet ports on my Orbi router stopping a couple of days ago. The wifi is fine (although it's died a couple times but came back when I did a reset). But, like the other people who have posted, when I detach the 8-port ethernet switch connected to the router, the other ports on the Orbi router start working again. I've updated to the latest firmware but the ports are still not working with the switch connected. Clearly this is an issue with the firmware or hardware if multiple users are experiencing the same problem. Can someone from Netgear please let us know if this has been recognized by the tech folks managing the Orbi updates and if they are working to resolve it. And if anyone finds a fix, please let us know. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had a power failure and then ethernet ports stopped working on the router.
I read online someone unplugged their ethernet switch (hub?) that was wired to the Orbi.
I tried that, unplugged the hub.
That did it for me. I then plugged the hub back in and now all is fine
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unplugging the switch worked for me too. Glad this got resolved!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just set up a new RBK. Wireless works fine but my 3 ports are working when plugged directly into the router. However once i plug it into a long cable it no longer works. Was working when I initially set it up. I have already done a reset!
- Mark as New
- Bookmark
- Subscribe
- Permalink
My lan and wifi ports stop working once a day seems to be no resolution talking to support
