RWCaines's avatar
RWCaines
Orbi RBR50 / 2 RBS50 satellites - WiFI speed extremely slow
We recently upgraded our Internet Service to 400Mbps through Spectrum but I can only obtain download speeds around 12-13Mbps over Wifi with the Orbi Router and two Satellites. What is also odd is that the Upload speeds are faster at 18 - 20 Mbps?
I am assuming it is in the settings but have not made any changes. Orbi router and satellites are upgraded to latest firmware 2.5.1.8 but this made no difference.
Any advice/guidance would be greatly appreciated
  • Retired_Member's avatar
    Retired_Member
    How long have you had your Orbi?  Has it ever worked properly?
    2.5.1.8 has some issues
    • RWCaines's avatar
      RWCaines
      We have had the Orbi about three years now, it seemed to work fine previously but to be honest, I never really checked the speeds until we upgraded our internet service with Spectrum. What I find odd is that the upload speed is faster than the download speed, it seems really strange to me
      Thanks
      • FURRYe38's avatar
        Thanks
  • plemans's avatar
    What modem are you using from spectrum?
    What speeds do you get directly connected to the modem?
    What speeds do you get hardwired into the Orbi router?
    • RWCaines's avatar
      RWCaines
      The modem appears to be Spectrum's own, no other identifying markings on it. Connected directly to the modem, I am seeing speeds of 480 Mbps download and 22 upload.
      Will have to check what i see hardwired to the Router, not easy to access, it is behind the TV in the family room
      Thanks!
      • FURRYe38's avatar
        What is the Mfr and model# of the ISP modem the NG router is connected too? Look for a sticker on the bottom?
        Built in router and wifi here by chance?
