- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK43 upload speed at 750+ mbps but download capped at 550 mpbs when wired?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey everyone,
So my internet is fibre running at 1 Gbps down/750 mbps up and I am using the latest .210 firmware and when I do a speedtest I get 750+ up but only about 550 mbps down. Is there a setting I am missing? This is using wired of course, my wireless speeds are fine. Any suggestions would be great, thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK43 upload speed at 750+ mbps but download capped at 550 mpbs when wired?
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Has a factory reset of the Orbi router and setup from scratch then go in and immediately test speeds with a wired connection? Don't enable QoS, Access Controls or Traffic Meter or IPv6 on the Orbi?
Might review these:
https://community.netgear.com/t5/Orbi/New-RBR50-Satellite-setup-some-thoughts-and-questions/m-p/1695...
https://community.netgear.com/t5/Orbi/Download-speed-cut-in-half-on-wired-connection/m-p/1695372/hig...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Siege7817 wrote:
Hey everyone,
- Do you use wired or wireless backhaul or a combination?
- What other wired devices do you have connected to Orbi?
- Is Daisy Chain enabled or disabled?
- What wireless speeds to do get?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
@Siege7817 wrote:
Hey everyone,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes when wired, upload is 750+ but download (which is 1 Gbps) is only 550 mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
This sounds suspiciously like the issue here ORBI used as Gateway Slower than 1GB Connection ...
Are you connecting with PPPoE on the Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
That poster mentioned:
"RBK50 to run at 1GBS via ethernet when setup using PPOE and VLAN201. When I test the speeds with ethernet to the centurylink ZyXEL C3000Z,"
Possible same issue, those he never fully completed giving details or updated about his status. I did refer him to NG support.
Hopefully something you can work with NG support to figure out why PPPoE is not up to speed on this protocol.
@alstsmith wrote:
Hi there,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Actiontec T3200M, ISP is Telus, ONT is a Nokia. I have no QoS, access controls or Traffic Meter or IPv6 enabled. I will try a factory reset and see if that helps, I tested with my laptop directly to the ISP modem and get 950+ as I should but as soon as I plug the orbi into the same port it maxes out at 550 mpbs but 770+ on upload. So definitely something with the orbi imo.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does Telus use DHCP or PPPoE for the connection from the modem to there services?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe it's DHCP. How would I check it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ask your
ISP. If you have access to the modem then you might beable to check there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ISP Protocol says Via DHCP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes with NG support. Check your inbox. Ask NG to capture your debug logs..
