Reply
RBK50 – Orbi AC3000 Tri-band WiFi System
shoeseller01
I
 have sent this email 3 times now to the ntgrapps_support@netgear.com without a response.
Hello,
I am a frustrated Orbi owner. I have the router and sat package. Bought at Best Buy. When initially setting up I was walked thru updating the firmware. I then upgraded my internet speed to 200mbps from 100 as I was told it could handle the speed.
I have a few issues. I go on the app and search for updates and none show up for the Orbi router. So with that said not sure what happened. I had called and I was told to disable daisy chain and a few other things. It seemed to work but I have issues where when connected to the satellite my Wi-Fi on my iPad, tv iPhone disconnects or lags excessively. The kids are at sleep and I’m the only one up. I check the speed thru the app. And the speeds are what I subscribe to. Then I do the Speedtest.net and the speeds are totally off. I disconnect the router and plug into my laptop and the speeds are correct.
I then reboot the System and they both turn blue so they are connected. I try to watch tv and again the same thing. It is hooked up to a amazon fire tv which I update whenever they are released. I restart that and nothing changes. So I have become used to the nightly loading and pausing of the system....IMG_4104.PNGIMG_4105.PNGIMG_4106.PNGIMG_4107.PNGIMG_4108.PNGIMG_4110.PNGIMG_4111.PNGIMG_4112.PNGIMG_4115.PNG
Also, on the connected devices. I change the names and assign them what they are and then the names revert back to another type of device and name changes to some other device.
My warranty expired for phone or chat short and I’m about to disconnect everything and return it to Best Buy.
When it works it’s the best. But lately it is not.
Any reports from others of the same happening?
Ralph
Message 1 of 11
Guru
Re: RBK50 – Orbi AC3000 Tri-band WiFi System
Which Orbi system do you have?
What FW version is currently loaded on it?
What MFr and model# ISP modem do you have that the Orbi is connected too?
200Mb is well with in the realm of speed handling of the Orbi system. My 40 series is connected to 200/10 on cable ISP.
I would try a factory reset and set up from scratch. Disable MIMO, Daisy Chain and Fast Roaming and IPv6 on the router.
Try manual channel 1, 6 or 11 on 2.4ghz and any unused channel on 5Ghz.
Any other wifi neighbors near by? If so, how many?
Are you using a satellite? if so, what is the distance between the router and satellite? Should start at 30 feet minimum.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 11
shoeseller01
see picture...
 RBK50 – Orbi AC3000
V2.1.4.10
Optimum - Arris brand, do not know the model number
When I had this issue, the company had me do settings changes and one of them was to disable daisy chain....not sure about the rest.
They also walked me thru the channel selection, not sure which one I'm on now.
There are neighbors on both sides of my home, about 50' each side.
I am about 30' + from the main router. Should I not have that set up?
My Setup (Cable 200Mb/10Mb)>Orbi CBK40(Gateway Mode)>HP 24pt Gb Switch.
R7800(Voxels v.4xSF FW), EX7500 and WNHDE111
Message 3 of 11
Guru
Please find the model# of the ISP modem when you can. Will help us determine if it's a modem only or has a built in router possibly.
Please try to disable MIMO, and Fast Roamnig as well after the reset and set up from scratch.
If you have wifi nieghbors near by, this could present a problem. Need to find out what channels there using and set yours to something different using 1, 6 or 11 channels. You might later on, change the power of the wifi radios down from 100% to 75%. If your using a satellite, you need to move the satellite a bit closer to the router since changing the power out put will reduce the range coming from the main router.
What is the distance between the router and satellite unit?
Message 4 of 11
shoeseller01
I do know it is a router only, I replaced the one they issued me with the Orbi.
Message 5 of 11
Guru
The Arris modem is a router only? Arris has modems only and modem/router combo units. So if you can get the model# please.
Message 6 of 11
shoeseller01
Message 7 of 11
shoeseller01
Sorry, I posted the wrong information. It is a Modem only. They had also provided me with a router, which I replaced with the Orbi system. The router is connected to the Arris modem.
Message 8 of 11
Guru
Ok, just making sure.
Give the other suggestions a try.
Message 9 of 11
shoeseller01
Returned it to Best Buy
I returned mine to Best Buy and before I did I asked the geek squad behind the counter. Lucky for me, I was there right as the shift was changing so there were 5 people.
Since they install and answer lots of questions, they did mention the return rate is above average and the support from NETGEAR is abysmal.
So I went and asked them which one they see or hear the least issues and they said the eero. I got that system and I’m happy.
Too bad but I had to. No one from NETGEAR answered any of my email or even in this forum. So with that said, I no longer am a NETGEAR Orbi owner.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 10 of 11
Guru
Re: Returned it to Best Buy
Understand.
Good luck.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1552 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
