Orbi WiFi 7 RBE973
Reply
Satellite RBR50 dead after firmware upgrade 2.5.0.38
orbira
Apprentice
Hi,
Today I upgraded to Orbi firmware 2.5.0.38. The router and one satellite came back up fine. 2nd satellite would not power on now. I have tried resetting, removing power etc., bout no lights, seems complete dead. Any suggestions please.
Thanks
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: Satellite RBR50 dead after firmware upgrade 2.5.0.38
Check the power adapter that plugs into the RBS.
Swap power adapters with the one that works for the other RBS.
Message 3 of 5
All Replies
Guru
Does it do anything? Is the power light on the back lit up?
If so you could try using tftp to do so.
Here's a thread that talks about recoving it with tftp.
https://community.netgear.com/t5/Orbi/Orbi-Satellite-corrupt-firmware/m-p/1636597
And the tftp utility instructions
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp from within windows.
https://www.thewindowsclub.com/enable-tftp-windows-10
Message 2 of 5
Guru
Message 3 of 5
orbira
Apprentice
Thanks. The satellite works after swapping the adapter. Now I need to get behind the entertainment center mess to figure out if it is bad power strip or adapter.
Message 4 of 5
Guru
Enjoy and Good Luck.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2803 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
