Orbi WiFi 7 RBE973
Reply
chromebook orbi DNS Server
smalldog
Tutor
Just purchased Orbi mesh router and now lenovo chromebook shows connection to wifi but when attempting to load webpages responds there is no intent connection.   Diagnostic reports - No function DNS Server.
All other devices work fine and chromebook works fine on other wifi (ie. not at my house).
Have tried restarts (chromebook and orbi) and powerwash of crhomebook. Nothing.
any advice?
Message 1 of 12
Accepted Solutions
smalldog
Tutor
Re: chromebook orbi DNS Server
So....  if that happens to you, all you have to do is reset everything by restarting modem, router and device.
Thanks to all who offered suggestions.
sd
Message 11 of 12
All Replies
Guru
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? IF so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure your device is set for automatic networking and IP addressing.
Have the device forget the wifi profile, then reconnect.
Message 2 of 12
CrimpOn
Guru
One thing that has happened to me (unintentionally, and I have NO idea "how"), was that a device would be "paused", which means that it connects to the Orbi WiFi, but is not allowed to access the internet.  I would also find that "Access Control" had been turned on and the setting was "Block all new devices from connecting."  ("Paused" is a term found on the Orbi "app".  The Advanced Tab->Security->Access Control uses the term "Blocked".)
Undoing those settings allowed my device to work as normal.
Of course, this may not be what it causing your issue, but is easy to investigate.  Also, it might be worth searching the forum for "Chromebook".  I seem to recall numerous posts about them.
Message 3 of 12
smalldog
Tutor
So...  I tried to follow what you described but when I went into the security tab in the app it tryies to get me to download another app...netgear armor.   Did you download that?
Message 4 of 12
smalldog
Tutor
So..  I understand a fraction of what you shared.
I can tell you that the router is sperate from the modem.
The router is RBR10.    Wierd thing is that I can use the network at my office...
frimware - v2.3.5.36
Message 5 of 12
CrimpOn
Guru
Oh, no... NO
Message 6 of 12
smalldog
Tutor
huh?
Message 7 of 12
CrimpOn
Guru
This is where I say, "Oh, no. NO."  If there are any problems, adding Armor to the mix will not help!
Message 8 of 12
Krb78
I am also getting issues with my kids chromebooks from school not operating properly when connected to the orbi mesh. I’ve had to disconnect it to get them working without errors- same with the smart TVs - 401 and 404 errors all over the place. Turn off the mesh, and it works perfectly (but then we are living w slow speeds) 🤦🏻‍♀️
Message 9 of 12
Guru
What model Orbi do you have?
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Is Circle enabled on the RBR?
Message 10 of 12
smalldog
Tutor
sd
Message 11 of 12
Guru
Glad you got it working and thanks for posting the fix.
Please mark your post as solved so others will know.
Enjoy. Smiley Wink
sd
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 4810 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
