- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS305E - VLAN Config
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
Hopefully this is an easy question to answer but have strggled for the last few days, trying every combination to get VLANs to work.
VLAN 10 - Management
VLAN 30 - Guest
VLAN 40 - Smarthome
Eth1-4 = These should be VLAN 40 tagged. They connect to devices like TV's or AMPS
Eth 5 = Truck to the rest of the network which has VLAN tagging working fine with WAC505's.
I've tried every combination of turning settings from T to U and also PVID to 40 for ports 1-4.
Attached is what my bad research says it should look like but doesnt work
Thanks for any help in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@C2L_Eu wrote:VLAN 10 - Management
No, ports where you connect devices like TV, AMP, computers, IoT must be always untagged.
The screenshots provided look correct, #1-4 VLAN ID 40 Untagged, PVID 40. #5 VLAN ID 40 Tagged. Double check the peer switch on the trunk is configued similar.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS305E - VLAN Config
From the above, what I can see all traffic still goes to VLAN 1 as the IP range is that default not VLAN40 which from what i belive it should be.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was the peer switch all along!
Thanks for you help
